So this is normal. OK, I won't worry about it unless it causes leaks from the gauge or copper tubing line. Actually I remember now reading something about some oil pumps being able to produce very high pressures but that the built-in bypass/regulators limit that. It would explain why the 60 psi pump I put in my 301 only shows 40 psi no matter what the conditions. The regulator limits it at 40 psi. As for low pressures, I once opened a Pontiac 400 and pumped solvent through the oil system to flush out crud. Just using a hand held drill and a distributor shaft as a priming tool I watched the solvent spurt out the lifter feed holes like gangbusters. The oil gauge I had monitering this would barely move. So even though the pressure was low- it flowed a huge volume.
