BlownSmoke said:
Haha, man-o-man! Now i dont know what i need. Im told one thing so i look it up just to be thrown a few more!!!
I was told since i no longer have a computer running my car i would need a lock out kit for my torque converter... You know the switch that disengages it at higher speeds???
Ahh, okay. Like other's mentioned this would be for your torque converter lockup. Of course the next question would be if you have the original TH-350C under there or if it was ever swapped out to a standard TH-350 over the years? If its the original then there will be an electrical plug on the drivers side of the trans that went to the computer.
If its a non-lockup TH-350 then obviously there won't be a plug.
And as said, you shouldn't have any problems running it without the lockup. I had a stock TH-2004R behind my 455 for years without lockup and it was never a problem. However, since you have it, you might as well use it.
😉 Should get you slightly better MPG and around 200rpm less at cruise.
I've never used a manual switch for the lockup due to the fact I didn't want to have to remember to flip it on and off all the time. I have used a few aftermarket lockup control kits with varying results. I had a TCI lockup kit that used engine vacuum to tell the converter when to lockup. That worked like absolute crap and everyone I've ever talked to that had used one said the same.
The other one I've used was made by B&M and adapted to the speedometer cable and locked the converter up based on vehicle speed. It was adjustable from something like 50-90mph. This one worked extremely well and the only thing that would have been nice would have been to tie it into the brake light switch so that when you hit the brakes it would disengage the converter.
However, it is expensive:
http://www.jegs.com/i/B-M/130/70244/10002/-1
There may be other solutions out there now.
As far as the safety switch, i have no clue what that is for. I have a floor shifter not a column shifter if that helps with that?
and like before
The neutral safety switch is there to keep you from starting the car in anything but neutral or park. If you didn't touch anything with the trans then it should all still be there and functioning and you don't need to worry about it.
