crossmember problems
86cutty
32
im putting a 700r4 trans in my 86 cutlass. I bought the jegster cross member for it wich is supposed to fit the car. my problemm is that only one of the bolt holes is lining up up on the driver side. Anyone else run into this problem?
in this case here you always want to install the crossmember loose, just enough to get the bolts in, however sometimes the holes themselves might be off, and that requires you busting out the drill
