Cruise Control on non Cruise Turn Signal Lever
H/O84
181
44
27
So I found that Dorman sells repop turn signal levers for our cars. I first saw a non cruise one for $7.99 and was hoping a cruise one would be just a little more. They sell cruise control t/s levers for $108.99. I would never pay that because I was only looking cause the chrome on mine has begun to peel off and the previous owner sprayed a little rust inhibitor through the window onto it. Has anyone ever tried to use the non cruise chrome base and attach the cruise controls to it?
http://shop.advanceautoparts.com/p/...49273/89015298-P?searchTerm=turn+signal+lever
http://shop.advanceautoparts.com/p/...9284/12019070-P?searchTerm=turn+signal+lever#
I imagine you could just wire it to a toggle switch and to the brake pedal to turn it off. I don't think it'd work. If the peely chrome bothers you that much, go yard hunting or just paint it metallic silver. Or black.
why not get a good used one, try L.A.X-Rated and O.D. Showtime
I just found a cruise one on eBay for $16.35 so I'll probably go with that one
I would trust the guys on this forum more than an ebay seller....
You don't seem to understand I don't need to replace this piece. It just something that doesn't look very nice because the chrome is starting to peel. I was asking if the $7 part could be use the with the cruise parts attached to the chrome from the one that isn't cruise to save money because Im not looking to spend much more than that on something i don't actually need hence why i was curious if that $7 one could be taken apart and made to work. Seems as if Ill have to experiment to find out.
Reactions: Pontiac455
H/O84 let me if that one on ebay works? I need a new one also. Send me the link the tge ebay one. Also if anyone has a used one let me know.
