Sounds awful cheap and don't forget the wiring runs to the bottom of the steering column. There is a knack for replacing that switch and if not done properly you will use some ugly words. I have replaced many and I used a piece of manual choke wire. It is stiff, relatively thin and strong. There is a hole at the connector and you make a "u" with the wire and hook the connector and cut off excess. Steering column in straight position. No tilt and gently work through the column as you remove the old switch. Hook new wiring to wire and pull back through ever so gently. Sometimes if you have a tilt wheel you may have to raise or lower one notch to work it through.
Remember
Patience grasshopper
Remember
