The best part of the Bonneville servo is that it is set up to be remote mounted, with a cable that runs to the carb. It plugs right in, but can me moved to a more visually appealing area (such as under the brake booster).
I mounted mine from one of the master cylinder bolts. It is mounted with the bracket that came off of the newer Bonneville, as it also retains the cable sleeve.
