ok so i took out the front amber marker lights and wanted to do more of a custom look then just throwing a LED replacement bulb in it....i went to the store and found some LED lights that kinda have the same shape as the front marker lights but not off set..(they are really suppose to go on a bus or truck) so i grinded the cutlass lights down to make it flat... i cut away the new marker lights... then i used my plastic welder to weld the seems..also i blacked them out with the night shade paint.. check it out.. looks pretty damn good.. all i have to now is grind a little bit of the excess plastic to make them fit in the stock place...
