Cutlass Chrome Steering Column
Qdub24
1,796
785
Columbus, GA
I need help finding a new steering column for my 83 Cutlass. I want a direct-fit, bolt-in, tilt, chrome steering column w/ignition switch. I got a floor shifter, so I don't need a column-shift column. Can anybody tell me any part #s, Flaming River, ididit, Billet Specialties, etc?
hp3445
118
Southern New Jersey
It would probably be wise to just call them and tell them what you need. They would know.. You can convert your column shift over for a lot cheaper. like around $70. Or look for a decent factory one on ebay... I just picked up one for $80. I just have to sand and repaint it. I was going to go the same route as you're looking at, but I decided to try and save the $400 for something else.
Remember then you are going to want to buy a new steering wheel, you don't want to stick an old wheel on a new column..kinda taking away from the whole thing. . but that can also cost big $$.. but it is nice to look at! Decisions..Descisions.. Good Luck!
Qdub24
1,796
785
Columbus, GA
Which one of the columns has the correct spline shaft for my 83 Cutlass? Also, which length is correct?
Floor Shift "Classic Bell" Columns
From Flaming River Industries
Flaming River now offers an integrated key column. The key is located at the 3 o’clock position just like you would expect from Flaming River. No welded on attachments or extra relays. Modeled after the popular Muscle Car Columns with Tilt and Ignition Key built into the column but still attractive enough to put in your street rod.
Flaming River manufactures the column complete with a GM coded key assembly, wiring and ignition switch. Flaming River uses state-of-the art, All New Components.
Columns also available in 28", 30", 32" and 35" lengths.
33" Polished/Chromed Floor Shift Key Column with 1"DD shaft / ea
#FR30001SS
Only $749.00
33" Polished/Chromed Floor Shift Key Column with 1"-48 spline shaft / ea
#FR30002SS
Only $799.00
33" Polished/Chromed Floor Shift Key Column with 3/4"-36 spline shaft / ea
#FR30003SS
Only $799.00
FE3X CLONE
2,714
51
48
Ohio
My stock steering column measures 33" from the face where the steering wheel mounts to the tip of the shaft at the other end. Not sure what spline it is.
The only problem I see with those columns is how do you mount it? On the stock column you have a u-shaped piece of metal that bolts onto the steering column and then bolts into the car itself. I don't see a provision for that.
How does it bolt to the firewall? These are all questions you need to ask them before spending that kind of money!
Qdub24
1,796
785
Columbus, GA
Thanks for that info. I'll be sure to ask them about it before ordering.
Blake442
6,866
2,011
Minneapolis
There's no wiper switch on that column either, meaning you'd have to retrofit your car some how, more than likely putting the switch back on the dash like the '81 and older cars. Not worth it if you ask me.
78PontiacGP
116
Queens,Ny
Ehh this will have to many people eyeballing it and along with the unwanted attraction
