Unfortunately, i don't believe so. There is a slight possibility auveco might have something like them, or scavenging for a cutlass in the junkyard would be an idea.I appreciate the reply. Worked like a charm, just had to put a little muscle on it.
The stud pictured is for the top two mounting points. Is it something I could find in auto parts or hardware store?
i went to my local hardware store and got bolts with the same thread pattern for my cutlass. just take it with you so they can match it up.
yeppers thats how i have mineAnd then just screw the bolt trough the mount into the header, now why didn't I think of that. Appreciate the info
Duh...what the heck was i thinking earlier? Thats a way simpler idea. If I'm not mistaken, the bolts that hold the license plate frame to the rear are the same size.yeppers thats how i have mine
yep but the bolts i got were double spline like the ends of the originalsDuh...what the heck was i thinking earlier? Thats a way simpler idea. If I'm not mistaken, the bolts that hold the license plate frame to the rear are the same size.
