Cutlass header panel bolts/stud removal help
Oldsdank81
39
Baltimore, Maryland
Swapping panels for a better condition one of the same year. The newer panel is missing a few of the mounting studs. Is the a way to remove them without damage to mount on my new panel?
Thanks for any input
81Regal
1,558
485
83
Terril Iowa
The studs screw into the header panel. Use a couple of nuts to prevent damage to the threads when trying to remove the stud.
Oldsdank81
39
Baltimore, Maryland
I appreciate the reply. Worked like a charm, just had to put a little muscle on it.
The stud pictured is for the top two mounting points. Is it something I could find in auto parts or hardware store?
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,815
Louisville, KY
Unfortunately, i don't believe so. There is a slight possibility auveco might have something like them, or scavenging for a cutlass in the junkyard would be an idea.
wonderboy24
1,322
1,301
Davenport, Iowa
i went to my local hardware store and got bolts with the same thread pattern for my cutlass. just take it with you so they can match it up.
L67ss
1,350
420
Just curious....what kinda condition is the old header in?
