WANTED Cutlass light blue sport steering wheel
Trader history (0)
Dark blue (27) was the only interior blue code I know of for 86 Cutlass. What's the SPID got on it for interior color?
I'm thinking you're looking for gray, ( code 82) which I believe your gray 86 you just got is this color based on what I've seen. This is the one I sold Mark Tupper after I sold my gray 85 442.
If I get around to putzing in the shop, I MIGHT....MIGHT...have a used gray sport wheel complete. If I do, I'll let you know. It may need rewrapping, though. I don't recall if I even still have it.
The problem with all those plastic wheels is that they do exactly what yours has done if not taken care of.
Looking for a light blue steering wheel for my 86 Cutlass. Not sure what the exact interior color is but its a very light blue that most has faded to an almost grey look.
Seats and floor look blue, dash and steering wheel look gray, in that lighting. Perhaps more pics from diff angles and less direct sunlight?
This is the pic I'm looking at below. This is a gray interior. I know it seems as if it's a blue hue for whatever reason. But it is gray. I'm sure the SPID code will read 82 if it's still there. Should also be on the body tag. 15 and 82 is on there, I'm betting. And whatever color letter the top is/was.
Not an Olds wheel Jake, but would either of these interest you? Both are grey Jeep wheels. The top one was on my Cutlass a couple of years. They would both look better without that big dumb horn button.
Sure that might be a good temporary wheel since the cars current one is so bad and quite frankly too nasty that i dont even want to touch it. The jeep wheels bolt right up?
Reactions: Sweet_Johnny
Yea. They use a Saginaw/GM column so they bolt right on. It's been a minute but I had to re-clock the horn wire or change the terminal end on it or something to get it to function correctly. Nothing too hard. Will you be attending the KYANA swap meet March 8th in Louisville?
Hadn't heard about it, however i will check and see if i can attend
