ok i was told he fornt ones can be cut with out tacking them out and im just looking for a few safe tips on how to go about doing that.or the safest was to remove the fornt spring
Depending on who you talk to ... this is either very simple or insanely stupid....I recommend doing a search in the chassis section....sure to be plenty on this topic therecutlass79 said:ok i was told he fornt ones can be cut with out tacking them out and im just looking for a few safe tips on how to go about doing that.or the safest was to remove the fornt spring
so uts best to just take them all the way out and cut them?pontiacgp said:the bottom part of the spring gets cut so even if you could cut the spring in place you wouldn't be able to turn the spring so it would sit in it's pocket on the lower control arm
