This has probly been answered plenty of times,but is there replacement dash/gauge illumination replacement bulbs that are recommended for brighter illumination w/o being too hot? This would be for my 84 Elky,that I got full gauges for an '84, from an '87 El Camino
Unless they're a wide angle, and you have the lighter colored surfaces of the inside of the cluster painted a reflective color, probably not. I'd still like to give it a shot though.
If you're gonna use LEDs here's a trick. Take some sand paper and rough up the whole surface of the LED. That way the light will spread out more instead of being concentrated to one spot.
I think I'll stick with standard bulbs,I guess.Stick to the numbers listed above? Or are there brighter versions...is 194 a brighter one than 168?-I also need to take the pod apart to see about the painting mentioned.Since its out of the Elky waiting to be installed & swapped with the 84's idiot lite version,nows a good time for everything to get done.I would assume new sending units need to be purchased.
Another thing for you to check is the area around the light too. It's designed to reflect the light so it illuminates the whole guage. But over the years these can get really dusty, or turn brown from the bulbs. And that's why most of the older cars guages are so dim.
So a good cleaning (and re-paint if needed) is a good idea. Since you will already have part of the dash apart anyway.
And if you do decide to repaint. Don't try and paint it a cool color to make ur guage lights a different color. I have tried this many times over the years and it NEVER works. Paint it the original color (usually a really pale light green) or just got with a bright white. If you want color, get the colored bulbs. But be warned, they won't be nearly as bright as with white.
