My gauge panel takes I believe 12-13. How many did you get for $10.00 ?Not much of an investment- $10
https://www.amazon.com/dp/B00JRE38EA/?tag=gbody-20
10. They have bigger packs, too.My gauge panel takes I believe 12-13. How many did you get for $10.00 ?
Did you use a white LED? I have found matching the color of the LED to the marker light works best and you can always "black out" or block the LED facing the lens to diffuse it and only have the light come out the sides.Just as an FYI: I took them out of the marker lights because it made a weird hotspot and looked trashy.
Yeah, but on the Bonneville, the bulb is at the bottom of the lens. An amber incandescent looks much better.Did you use a white LED? I have found matching the color of the LED to the marker light works best and you can always "black out" or block the LED facing the lens to diffuse it and only have the light come out the sides.
That’s interesting and good to have. I’m going with the LEDs so I guess it doesn’t matter now.Found it
