This is a short write up of the dashboard re-vynl that my wife and I did on my GMC and the thumbnails
As you can see there is the dash, in its original glory. It was starting to crack really bad plus I always hated the three tone brown interior of the car.
This is the after shot. I had to jam it in before anything was ready to take a pic. The previous owner was allergic to masking tape and painted over all the chrome on the car + half of the plastic interior around the door jams glass, blinkers, tires ect... This whole project started because I can make things look better (starting with a razor blade and a scrub pad)
Here is the ugly part where things were stressful. the part before the intricate cuts.
I found it easiest to do small shots of glue and only focus on sticking one part at a time. I started in the top middle and went straight down to the heater/radio box then left then to the right side. I had help the entire time which made it real easy.
This is another small step. I think a little heat would've sped up the process of drying and molding the material.
I did the cover here and I shouldn't have. after it was done it closed the tiny gap around the edges and its a tight shut. I'm not too sure how long it'll last under normal operating wear. Hindsight I would've painted it black I think because it never had vynl on it to begin with. Looks really good though covered. Same with the piece that covers the bottom of the steering shaft and has a vent in it. I never took pictures of it and I put gauges there.
This is my upholstery shop. Notice its a pool table on my back porch. All my previous experience stems from "I think I seen a guy do this before"
