It does go to that pod… does the end I’m holding just plug into an empty spot on the plastic connector that the ligh switch plugs into? Thank you for your help. I just looked through all my books and cannot find that anywhere.Looks like a fiber optic cable that goes to the light switch. Follow the cable back and you should find a gray pod you can take apart. Inside is a bulb that when the ignition is on, the bulb lights up so you can find the light switch in the dark. It's just a little blue dot on the light switch. It gets pushed into a clear clip on the back side of the light switch.
At least that's what it looks like to me. I could be wrong.
Thank you very much!!!Yup. Snaps into the clip on the outboard side of the headlight switch. But many times that clear plastic part gets broke and that's why the end is hanging loose. Fingers crossed.
I don't think you'll find it anywhere in the books. At least I don't recall that.
