Definate nOOB here
I've heard good things about Howards cams and other products. That's a pretty "big" cam. The lobe separation is about right for what you want but that's quite a large duration for a street car. It would work well with higher compression and a large stall converter. It will kill a lot of your low end torque and move your rpm band up. You could definitely use a set of 1.6 rockers intake side and exhaust side as that is not very much lift.
well come to find out that summit racing had the duration listed wrong on the internet. its a 274 intake 286 exhaust i think duration. i want the 1.6 rockers but my funding is run low. i dumped 600 in the motor alon this week. i would have hoped on the forsale forums there would be more performance parts for sale but it seems to mainly be interior and body stuff.
Well its not so bad on the column ive seen guys take the column lever out cut the lever bracket off then sand it level and either put tach, there over it or you can usw a little fill and fill sand paint ,then when you buy a aftermarket shifter it comes with the cable and its flexible,cut hole where you want it to set and your ready they supply all brackets you need for then trans you will use, grand.prix floor consoles are hard to find and expensive if you do so you can modify a fbody console or the more common ss monte console and bucket seats the same ive been told fbody seats bolt right up in front but for a match you have to get custom work done. Look around this websites members pics and you will.see alot .of different car seats.and consoles.swaped into gbodys and.they look good .
