I recently had to drill a bolt out on my intake which involved me having to remove distributor carb etc. Since then i've had to replace the coil. My carb is a Speed Demon 750 w/ vacuum secondaries. Well i've got everything back together timing is almost right but I've got a few hick-ups. After pumping the throttle linkage a few times after i finally do get the car running it idles pretty high 1500 is the lowest so far. When i give it gas it stumbles or hesitates then picks up speed and holds for a min before slowly reving back down. And The motor shakes excessively, so much to where it shakes the battery. its got 4 corner idle mixture screws all are set 1 turn out right now but i've played with it from all the way in to 2.5 turns out.
My cam is comp cam 284h so i expect it to be lopey. I've had the car running fine a few weeks ago so i dont want to change anything unless its absolutely neccessary. I'm removing the carb tomorrow to take a look at the power valve and set the butterfly blades to the transfer slots. I don't have a timing light but i'm working on getting one this week also so i can talk real numbers eventually. Spark plugs are new but i'm pulling them also to test. plug wires and distributor are new also.
I want to be sure i'm going about this the right way and that I'm not over looking something. Thanks
