I'm not dead set on this, and I'm simply looking for better fuel economy. I know diesel is more expensive, but 30 mpg for $6.00 sounds a little better than 20 for $5.00. I think what I read about 33 mpg with a 6.2 was with a 200-4R in an S-10.custom442 said:The problem with this idea is the cost issue. To save gas or pay less at the pump, its obviously a terrible idea. *snip* 33mpg is bullshit btw.
I don't necessarily care if it's a speed demon, but I do want it to get out of its own way. If it will have pretty much the same power of the 4.1 with better fuel economy, I'll be satisfied. I've also considered an SC3800 swap, but if the 4.1 can top 25 with a proper tune, I might just leave it alone.
What I don't understand is why you think the 6.2 wouldn't top 25 mpg with overdrive in a mid-size car. Not to argue, but I have read EPA estimates of 29 mpg highway with a 5.7 Delta 88 Olds diesel. My uncle also has a 93 GMC 2500 6.2L with over 300k miles that gets 28 mpg on straight diesel, and he doesn't even take care of it. He's the kind of guy that will spend $10 to save 10 cents over doing something the right way, like mixing 16% gasoline with his veggie oil and dumping it straight into the main tank with no heater. It gets 21 on his veg-gas oil. I'm just patiently waiting for his injector pump and pistons to fly apart.
I have personally gotten 25 mpg cruising at 80 mph with a 3.8 Regal, 200-C and 2.41 gears. Granted the 6.2 is about 65% bigger, but bigger engines don't work as hard, and with an overdrive, I would imagine it should do better than 25, if it gets 28 mpg in a heavy pickup with lower gears?
I am wondering if I can simply order a new set of front springs for a 5.7L diesel Regal? Was the 5.7 about the same weight as a 6.2?custom442 said:Stiffer front springs and some suspension mods will be needed, the 6.2 is a LOT heavier than whats in the car now. You won't get 33 mpg and should be happy with 20mpg.
If I'm not mistaken, I think they were only offered in the Cutlass and Regal, I have never seen a Grand Prix or Monte Carlo with either one. According to what I've found with Regals, the 4.3 diesel was only available in the base model, if you had a Limited, it got the 5.7. Strange. :shock:upandaway84 said:Anybody have an idea as to which Gbodies had the RWD V6 diesels in them?
I am curious what gearing would be best if I were to build the 200-4R to accommodate? As to computer programming, the 6.2 I have is the first model year, no computer to it at all, it is completely mechanical. And when you say diesels don't care about weight, are you saying that less weight will not help economy, or are you saying that more weight will not matter?megaladon6 said:Some things to keep in mind about diesels
1) they drive like dogs more because of the gearing than the engine. MUCH more
2) the newer ones dont have the greatest MPG, due to emissions. All of that is in the computer programming---its easily changed. The only other limits are injector nozzle and turbo size.
3) diesels dont care about weight
I am curious, what kind of fuel economy did your 4.3 V6 diesel get?MR442 said:I ran V6 diesel for year as a beater car . Could beat about any MPG in a gas car of same size today big time . Also Had V8 in the 98's . Hey 10 MPG more in a car is a big thing . 403 got 20 Plus the same in fuel form almost 30 mpg on trips. Loved the V6 by the way . Wish got more than 200000 miles out of it tho.
