digital dash
bigdawg
364
ever since i took my turbo 3.8 out and put my 350 the digital dash dont work and not knowing how much gas i have is getting old and same with not knowing how fast im going lol
i completely cut out the harness for the 3.8 and there was a couple wires from under dash on passanger side spliced to it could that be a reason? im hoping it just needs a positive and ground connected to light up and i checked my fuses
Not enough info for anyone to really help you with this. What you have to do is get under your dash, look at your wires, look at your fuse panel, check all fuses, then if you have to, remove your dash and trace the wires, check power and ground wires using a test light and try to find the problem.
Other than that, I dunno if anyone else can tell you what else to do. Good luck.
