dimmer switch
chevy94ss
May 23, 2006
51
owasso, oklahoma
www.cardomain.com
any one have a write up on how to change out the dimmer switch on a 85 cutlass? my dash lights are out and i think that the dimmer switch is the problem. if anybody has and insight or experience w/ a similiar problem please let me know.
May sound like a dumb question, but did you check your fuses? My '81 manual shows a fuse inline to the instrument panel. '85 might be different, but probably not much. Do your dome/floor/etc. lights work? If not then I'd probably blame the switch, if they do I'd look to that fuse or a ground.
[Edit: Derrr, I need more sleep.]
well if ur going to replace it, you need to pop off the wood grain on the left side next to the instrument panel, and there should be 2 7mm screws. one on top and one on the bottom
