I see what you are saying Dave. Put in the Express van master cylinder, but put the caprice reservoir on top so that it is angled.
Jim, do you have a part number for that Riviera master. Does that have a 1 1/8' bore as well? I looked at RockAuto, and the ones I saw have a 24 mm bore. What makes them work better?
Streetbu, bleeders are on top. I even unbolted the caliper to make sure that the bleeder was at the very top when I bled them.
Master cylinder for Blazer brake upgrade with C5 fronts and (stock drum rears) 12/18-upgrade to rear disc
When I spec'd out my brakes I talked to wilwoods tech department a bit and even with the 6 piston fronts and LS Fbody rears they recommend a 1"MC with the 8" dual diaphragm booster. I was looking for a bit more travel for modulating with the pedal. The LS Fbody rears fit inside my 15" rims. No...
gbodyforum.com
See post #32 for the part numbers. Read the rest for the issues I had and resolved.
