This master bolts right in no mods
AC DELCO Master Cylinder Part # 89056529 or 18M974 (same master)
98-02 f-body brakes front/rear using my stock master and prop valve with no problems so far. Checked the new master before I put it on and it didn't have that 10 psi residual pressure valve that's needed for your rear drums. That valve needs to come out if using disk/drum master when disk brakes on the rear of our cars.Thanks for all the input on this thread.
I'm just starting C5 front discs and '00 F-body rear discs with 18" wheels on my '79 Malibu.
I'm very curious who has done this or something similar and what master cylinder, proportioning valves really work.
Have you confirmed that this 1" bore master will slide into the recess on our brake boosters? I tried a 1" bore master I had and it wouldn't fit my booster so I had to go with a stock replacement. This would be great if it does indeed fit.This master bolts right in no mods
