Lorenzo said:Haha ok good to know. Always see them on TV and the hosts like praise the product, guess they have to because there a sponsor... :idea: I just want to upgrade those parts of the motor for now. The MSD Wires would have to be better in performance and efficenicy vs the Crappy Delphi wires i have now right?
Honestly, if you are running a stock ignition setup/stockish engine, I do not believe you will see a difference (other than in your wallet). That's just my opinion on the subject. I usually run AC Delco or Bosch plugs and the same on the wires, unless I am working on a high performance application that includes an upgraded ignition system. In that case I've used wire sets from MSD and Pertronix with success. As for spark plugs, I feel most are pretty much the same. All the "testing" done to make you buy a particular plug is typically done with new plugs. I would like to see these companies provide a Horsepower/Torque/mileage chart after a few thosand miles. I suspect the difference will be marginal. If you change plugs frequently, get a good quality copper plug. If you would like to go longer between plug changes, go with platinum or irridium.
