If you are doing the blazer brake upgrade you will no longer have wheel bearings as they use a hub assembly. I would recommend when you do the upgrade remove the brake sensor plug from the hub and shoot some bearing grease down into the hub assembly. If you have the extra money riffraff makes greaseable fittings that go in place of the sensor which now makes your hubs greaseable with a zerk fitting. I have them on mine. Makes for good service so you don't have to replace the hub unless it's shot.I just saw other people covering license plates, I assumed it was for a good reason. I hadn't considered a new radiator, we'll see how far I get. plugs are good, wires I believe are the same as when I got it. Belts are good. Fuel filter oil filter and change are on the list. Brake lines I'd bet are original, tires have tread but are quite old (one of the two reasons I'm looking for n90s) Should I put new front brearings in when I do the blazer brake upgrade? I dont have the desire to repack the old ones (dont have enough tools or space to work with). Finally I'll take your advice on the headlights, plan on doing those with a friend who knows more about electrical... and sticking with the halogens that come with the h4s
You learned well young grasshopper...If you are doing the blazer brake upgrade you will no longer have wheel bearings as they use a hub assembly. I would recommend when you do the upgrade remove the brake sensor plug from the hub and shoot some bearing grease down into the hub assembly. If you have the extra money riffraff makes greaseable fittings that go in place of the sensor which now makes your hubs greaseable with a zero fitting. I have them on mine. Makes for good service so you don't have to replace the hub unless it's shot.
