now before i try this an brake off things or start cracks an whatever else that could happen how do you remove the interior door panel
carmangary said:In additional to the plug clips, the top of the the top panel has tabs that are inserted down into the door frame. You have to lift up on the panel after the plugs are freed. But, in order to release those top tabs you have to reach under and push them with a screw driver a bit. If you don't release them properly, odds are that they will break off and the top of your panel will be forever loose. Those tabs are part of the door panel and can't be replaced of fixed.
