Hey Gang I recently changed out a window motor and noticed that the door pull strap had different size screws. 1 being the original and the other twice the length. As long as I've owned these cars, I've had varying degrees of those screws holding like they should to backing out on their own and of course the hole getting stripped. Has anyone considered making an improved method of attaching the straps to the door? I was thinking of installing some clips that retains a nut or is threaded that the appropriate size machine screw/bolt would screw into. I have no reservations blowing holes in the removable piece. The rear hole, it's going to take some thought.
