I have a issue with my drivers side door that i am trying to fix...
The upper hinge roller is broken and the door kind of sags a bit i went to autozone to try to pick up a hinge repair kit but the hinges or bushings dont seem to be able to repair it. I was going to buy one but its kind of of expensive. so is there a way to replace the roller or should i get a used one from the junkyard? Do hinges from any 2-4 door g-body fit? i was going to just jack up the door and adjust it but i figure i should fix it right the first time.Is there a replacement roller? Thanks
