Doors
90hurst/oldsguy
167
Has anyone had issue with their doors not adjusting all the way in on the door hinge side? I know my car has received some type of damage to the lower quarters but the doors are letting in to much air for my liking
do the doors stick out further than the fenders ? if not it might be time for new weather stripping the doors are really a pain in the butt to adjust you don;t want to go there unless you have to
The doors stick at least half of inch when closed
If it's only at the back, move the striker in or out. It looks like it needs to go in, but it's possible that it needs to go out if the latch is only closing on the first detent. Actually, take the striker off (mark position first) and hold the door shut and see how it lines up with the front fender. The striker should only be used to adjust how far in or out the door is at the rear. All other door adjustments should be made with the striker removed.
door the doors stick out more then the fenders meaning where the door and fender meet also there are 2 catches on the door latch you push it in a little it clicks push it in more it clicks in tighter do you get 2 clicks ?if only 1 the striker on the quarter has to come out if you get 2 the striker has to go in
It as always been one cli
