Dorman replacement outside door handles (mod needed)
HAFROD
2,179
3,334
Claremore, OKLAHOMA
These are the ones marked HELP at most auto parts stores. Just wanted to let you guys know that the hole that the actuator rod goes into may need drilled out more. I'm assuming the chrome plating had the hole smaller. I drilled it slightly bigger and the rod end slid through.
