^^^sounds sarcastic, but he is spot on. There is not a predefined length for every transmission and rear end combination. It's relatively obvious if you consider the differences in rear end yokes - there is no way anyone can provide an exact lengthOne that is the correct length and works, get one built.
I have the frame out so I will wait to get the weight of the body back on to get a correct measurement was just trying to save some time I know I will have to wait on having one made thanks for setting me straight^^^sounds sarcastic, but he is spot on. There is not a predefined length for every transmission and rear end combination. It's relatively obvious if you consider the differences in rear end yokes - there is no way anyone can provide an exact length
Thanks for your input brother your rightThat and Engine mounts, not all are in the same place. Way too many variables.
I do not advocate the cheap junkyard one that "may work"... spend the money here, it's worth it.
