duel gate shifter
V
VINCE363
n00b
Jan 6, 2019
i have a 1978 olds omega with a t350 trans i want to install a floor duel gate shifter what do i need to connect it to the trans to work any one know thanks you can contact me directly at [email protected]
Thread starter Similar threads Forum Replies Date
I Throttle position sensor? Fuel / Air / Boost / Emissions 57
P Power Tail Gate - Weak? Wagons! 9
Tuffregal83 Nos tail gate weather strip Wagons! 17
Reddzedd Malibu Wagon trunk gate? Body / Trim / Paint / Glass 5
442kid 1987 Monte SS parts For Sale Sport Steering Wheel, Tail Lamps and 200R4 T Handle Shifter Set up G-Body Parts For Sale / Trade 1
S floor shifter General Discussion 3
84cutspreme CUTLASS quicksilver shifter Oldsmobile Cutlass / 442 / Hurst/Olds 3
J MONTE CARLO Installing b&m automatic shifter knob Chevrolet Monte Carlo / SS / Malibu 0
SmokinJoe CUTLASS 83 Cutlass Shifter question Oldsmobile Cutlass / 442 / Hurst/Olds 0
nummbr7 Twist Machine Paddle shifter $300 G-Body Parts For Sale / Trade 1
442kid 1980's MONTE CARLO SS MALIBU EL CAMINO 200R4 SHIFTER CABLE & LINKAGE G-Body Parts For Sale / Trade 6
gnvair Factory A body 4 speed Hurst shifter on Ebay Chevrolet Monte Carlo / SS / Malibu 0
CDUNIGAN1981 Pontiac OD shifter (Quicksilver on console) Transmission / Rear End / Driveline 4
T shifter cable Oldsmobile Cutlass / 442 / Hurst/Olds 4
565bbchevy Shifter mount stands General Discussion 1
gnvair MALIBU Installing a Super T10 4 speed in place of a Saginaw 3 or 4 speed in a 78-81 A body without moving the original shifter hump. How-To's / Knowledge Base 22
Chevytruc1658 3 speed Lightning Rod Shifter Transmission / Rear End / Driveline 6
chevyy_rollin47 700r4 floor shifter on Monte Carlo SS Transmission / Rear End / Driveline 0
chevyy_rollin47 Floor shifter conversion 700r4 General Discussion 9
Kwyk85_442 Hurst Shifter to 4L60E Trans Cable G-Body LS Swap 0
T T56 magnum shifter placement Manual Transmission / Clutch / Shifter 11
Fishbait17 Mega shifter New Users 24
chevyy_rollin47 column shifter to floor shifter conversion Transmission / Rear End / Driveline 4
E Column shifter issue 85 el camino Transmission / Rear End / Driveline 0
flatout Swapped transmission from 200-r4 to 700-r4 shifter cable trouble Transmission / Rear End / Driveline 4
F Shifter cable routing Transmission / Rear End / Driveline 11
dickeymoore 700R4 with column shifter????'s Transmission / Rear End / Driveline 31
wonderboy24 shifter cable G-Body Build Threads 3
T 455 and column shifter Engine / Swaps / Driveability 6
4 Floor shifter differences 3 speed versus 4 speed? Oldsmobile Cutlass / 442 / Hurst/Olds 4
Similar threads
