I've established now that the motor in my '78 Impala, the original 305, needs valve stem seals. Bad. Problem is, I don't know what I should get. Are there several different styles of valve stem seals for SBCs or is there just a one-size-fits-all?
It's a totally unmolested stock 305 2bbl, so I presume it has stock heads and nothing's been changed.
Would these seals from Fel-Pro work? I've heard that the blue and white things cut down on cold start oil smoke as well (well, what of it comes from the valve stem seals, haha). But someone else mentioned having to do some sort of machining to make them work, and I'm not fully sure why these would help (unless I just need to see them in action)-
http://www.summitracing.com/parts/FEL-SS72527/
http://www.summitracing.com/parts/FEL-SS72526/
Anyone have any suggestions/thoughts?
