Hey all. So, thunderbird update. After it broke spring break (hah) I have to order new lower control arms. I got the driver's side delivered from MacsAutoParts out in New York (160 per arm, 207 with express two day shipping, 249.99 at autozone *hell no*) and I will order the other side next week when I get paid. NOW, being as the car is 45 years old, it needs new upper/lower control arm bushings. As you can see from the picture of the control arm, I put new end links, shocks, and front swaybar bushings as well as 4 new ball joints. I went with moog for the rubber and monroe for the shocks and duralast for the balljoints, which are all fine btw. Worked great. SO, should I get duralast/master pro upper and lower control arm bushings? This car will pretty much be a DD until snow flies again. It cruises surprisingly well or at least it did. I admit I splurged a bit on all the moog stuff, but with these will it really matter? I don't want to spend 3x the amount for bushings the size of a walnut if it isn't going to make that much of a difference. Thoughts?
