eBay Speed Daddy 1 3/4" primary headers fitment?
BlueBullet87
6
25
North Carolina
http://www.ebay.com/itm/-/381056792351?roken=cUgayN&soutkn=Bm2hMb via @eBay
Hi All!
Wondering if anyone has tried these (likely Chinese knock-off) 1 3/4 primary tube headers ?
I'm particularly interested in fitment with the HVAC box left in place.
So many of the other larger tube headers on the market don't fit with the a/c box, or the Hookers have the tube outside the frame rail. OR others are super high $$$.
The eBay seller responded that they will fit with "stock" equipment, but that's all they can say...
Thanks!
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Funny, I noticed these too. I dug through about 2000 feedback posts for Speed Daddy, and only twice did these headers come up - both with positive feedback - but none of it had to do with fitment. Might be worth the $160 risk.
565bbchevy
9,619
12,711
Michigan
I bought a set of their 1-5/8" headers (have not installed them yet) but the design is a copy of Hooker's 1-5/8" Gbody headers.
They look good and the price is right but I did had to buy some special copper header gaskets to match the D ports on my Edelbrock heads and still seal the large oval shaped port on the headers..
For the 1-3/4" headers it does look like the tube could interfere with the ac case but for the price you could try them and resell them if they don't work out.
motorheadmike
8,976
27,522
I was considering them for a car with a non-AC heater box, not sure if that is better or worse. The reason I like idea of these are the completely pointless 3.5" collectors which I would want to marry to a Pypes 3.5" x-pipe kit and some pre-axle dumps. Noise for the sake of noise.
motorheadmike
8,976
27,522
So after a bit of sleuthing I figured out that the eBay headers in question are a knock-off of the following header designs:
http://www.schoenfeldheaders.com/street-stock.html
P/N 186
https://www.afcodynapro.com/DYNATECH/1100167145
P/N 701-22010
It just so happens that my brother has the Schoenfeld 186s on his car. You can see that it fits just fit around a non-AC heater box and fits fine on the DS as long as you delete (or significantly modify) the stock linkage from the column to the trans - find a new way to get your neutral safety switch. So for the same money you can have a cheaper stainless version that will last longer than originals.
