Working on a 83-305-Q-jet. The car had issues before it came to us, and has sat for some time.
Work done so far: carb rebuilt including throttle shaft bushings and bench adjustments. Initial idle mixture screws are guesstimated at 2 turns out.
New coolant temp sensor/connector and O2 sensor/connector after testing out bad.
All other sensors Baro/MAP, TPS, test out okay.
EGR appears to be okay. With some difficulty I can get it started and run pretty smooth on the choke and fast idle cam for a few minutes. After it's warm it starts to get rough. pulling the choke off makes it stall. It seems to be very lean and only able to run with the choke almost shut. Once it's very warm it will idle very roughly for a short time with no choke until it seems the ECM finally kills it. The dwell test connections shows that the ECM never achieves closed loop operation.
I haven't found any real bad vac leaks, though I'm still hunting. My next move is to check all of the wiring to the ECM for continuity. Other than that I'm at a loss at what to do to make this thing happy. Pitching the carb and dist for something non ECM is close to happening, though I don't want to spend that kind of money to get it going.
Anyone have any other ideas for culprits?
