Does the ECM control the factory gauge cluster? My 84 ss had an all mechanically controlled 350 swapped into it by the previous owner, and since then my lockup converter does not work even though still connected to the ecm. So last night I started testing the wires that run to the trans, and tried to toggle switch the torque converter(unsuccessfully). When they swapped motors they chopped every wire on the firewall on passenger side except for the transmission wires which I traced so I am sure of. Well to make a long story short.. After I played with those wires I lost my factory tach, volt gauge, temp gauge, and fuel gauge. So my guess is I fried the ECM, but I was unaware that all my factory gauges are controlled by it. I don't know what else it could be. No blown fuses. I also am running aftermarket oil pressure, temp, and volt gauge, so I can live without those, but I can't go without my fuel gauge. :?
