Edelbrock 1407 carb issues
crotchss
314
61
48
Kearney, Nebraska
Hey guys, needing some help as I'm currently stumped and I know talking with you all, someone will have the right answer for me. Well I know this isn't in my SS, but thought I could find help here anyways. In my 1989 Chevy K1500 I pulled out the TBI engine and I have installed a 406 SBC with TrickFlow heads, Comp XE274 cam, RPM Airgap intake and a Eddy 750 carb. The problem I am having is after a year of having this thing together it just started backfiring through the carb under hard acceleration. I had previously jetted down the carb on the primary and secondary for better fuel economy with no issues and ran it this way for 9 months. Checked plugs and they were all clean white with little tan, so I jetted up all back to stock and even went a few stages past on the rich side with no change. I also upped the step-up spring from 5" to 7" to get it to go to the power mode a little quicker with no change. When it backfires it is a repeated backfire under WOT but if I lightly and quickly flutter the gas pedal from floored to just a little less it is fine. I'm going to change the carb to intake gasket to see if there is a leak there, also check fuel pressure to see if pump is weak. Also thinking of changing the pick-up coil, but with the fluttering of the pedal kinda getting it to not backfire I don't think the pick-up coil is the problem. Any other suggestions guys would be greatly appreciated. Thanks
the problem is the eddy carb,,, its junk and needs to be melt down asap,,,
they have 2 floats,2 power pistons or whatever its called,
anyway, for the money you could have a nice quadrajet from sean murphy induction , hunnington beach , cali
We have 1 Eddy in the house. They seem to like more initial timing at idle. An overlooked item on old distributors is the vacuum advance. FYI the vacuum port on the pass side of the Eddy is for the dist. The driver side is constant vacuum. Everyone please buy a vacuum gage. The dist port/whatever carb/ should have no vac at idle. The gage will show increase at throttle up. 🙂
