edlebrock carb problems
84cutlass454
105
35
i got a 750 cfm carb and when i brake torque the car is like breaks up or like hesitates at about 3400 rpms then i punch it to about 5000 rpms it just fine the smoke starts to roll i dont know what the problem and when i go to adjust the needle and seat with a vacuam guage it dont change and i can close them all the way and it still runs and i cant put my hand over the carb anf it dies so i know it dont have a vacuam leak
need to clean that carb out lol
with the car running take out each mixture screw and shoot some through there if that dont work need to pull carb pull both screws and use air pressure to blow out each idle cicuit after that it wouldnt a bad idea to run a can of seafoam through the fuel sytem
Scrap that eddy carb and throw a holley 4779 dp on her, your problems will go away...... I had a eddy 750 on my ride and all it did was bog down off the line then after a sec or so it would run like a raped date............scrapped the eddy, put on a holley and now the bog issue is gone.....
yeah thats what i thought it was just a carb to get it started so i checked it out and i am a holley man so jegs here i come i will be buying a 850 to slap on there and it seems that the eddy hides cam duration to just my thought. thanks alot again guys for the good info.
never mind on te eddy dry hopped it today it bogged and died on me i have had it with this pos carb never a gain i rejetted it according to the book a ned rods in it and still the same thang now i am whating on my holley to get here so i can throw th eddy away lol holley hands down sould of knowen better.
