I have a scenario going on here that has me currently stumped. I have a Holley Blue pump and a regulator that have been on the car since before I bought it last April. Never had a problem.
This weekend I installed a canister filter on the suction side of the pump. The salesman on Jegs showroom floor told me, it should be an ok thing to do. At the same time I installed a new liquid filled gauge on my double pumper mainfold. The new gauge showed 2.5 PSI less than the old gauge did (7PSI). I just figure the new one was more accurate.
I test drove the car down to Jegs(20 minute drive) to take back a few items, before I adjusted the pressure up on the reg. After all, I wasn't planning on racing anyone. It drove and ran as it should.
20 minutes later, won't start. No fuel pressure. I have no tools to try and turn it up. Waiting on a buddy to rescue me, another 30 minutes goes by and I happen to recheck the pressure. Now it is up to about 3.5 PSI. Tryed to start the engine, and VROOM, starts right up.
Drive it home, pull into garage, with engine still running, 0 PSI on gauge. I turned it up to 7 with it running. Take it back out for a spin around the block. Come back check pressure, about 6.5. turn it up to 7.
Went back out 30 minutes later, turn on pump. 9 PSI????
About 1.5 hours later, 13.5PSI????
So it seems, if the car is hot the pressure drops. As it cools, it raises.
I knew I has 4.5 before, when it dropped to 0, I added 7. Now when it is cold, take the 7 and add it to my original 4.5 and you get what my pressure went up to after it all cooled down, 13.5 PSI.
The fuel filter is the newest thing in the configuration. Could that be my problem?
Or any other thoughts?
