electric fuel pump
shotgun said:
None of us can really give "good" advice without more info from the OP.
On a side note, Carter are the only pump that I know that allows free flow threw it when off.
Back, way back, in the day they sold a trak-pak which was a inline pump.
Years later we put a carter back at the tank inline, it was wired to the n2o arming switch. We put a T fitting where the hard line turns to rubber right near the d/s footwell (A-body). The one side went to the mech pump and the other went to a n2o solenoid.
Worked well for someone who did not know what they were doing!! Maybe we just got lucky, never hurt the motor running a 150 shot.
Nice injection set up 😀 wish you had pics of it.
Carter always advertises the best numbers on pumps, but I've never tested them out personally.
thanx for all the replies! Currently she is a work in progress! the short block is just assembled, 383 stroker scat forged crank scat h beam rods kb pistons, double hump heads. She will also be runnin on a 125 shot or 150 not sure yet (lol) the way the machine shop is figuring a solid hp 425 (motor) 550 juiced she will be backed by a th400, also by a 9" rear 4:11 gears.
