1983 Hurst olds 307 I have been searching everywhere to find out what this is called and where the line coming out goes? Part numbers or cross reference source
Any help will be greatly appreciated
Thank you where does the wire go? It is cut or chewed throughThat's the vacuum operated heater control valve for the HVAC system.
Thank you that makes sense.Splice in/slide on a section of vacuum hose to repair/over the damaged section.
That gray hard vacuum line runs into the firewall to the heater control.
