Ok, please don't take this as criticism. This fandangled interweb can make one's comments sound condescending and downright rude. But first of all, you said a carb is cheaper, can be as efficient, and has more power.
You have a carb in mind? Do you have one already? Can't get any cheaper than free with the TBI setup you already have. I'm assuming you will get a new intake. That's even more money. Then you probably want to get a different distributer. More cash...
Now, far as making more power. I know just enough about carbs to make me dangerous and learn more every day. Mine is probably not setup perfectly. Again, please don't take any offense, but if you are asking about motor mounts to use, what driveshaft mods will be necessary and who would be able to do them, if the trans is controlled by the ECM... how confident would I be in being able to tune a carb to get me more power than the TBI would? You would also probably want to run dual exhaust and maybe even headers to make the motor breathe better and find that extra power. And as far as gas mileage (efficiency) I think the TBI would do a better job than a carb would.
This is totally meant to be friendly constructive criticism. If you like carbs, don't let the truth change your mind (joke) and go with a carb 🙂 But TBI, especially if you already have pretty much everything to get it going, would be very attractive to me. IMO, it would be cheaper, easier, more efficient, and probably make as much power all things concidered. I would yank everything from the truck I would need for it, just in case.
Good luck in the install.
D
D
