86 cutlass supreme has had a few engine and trans swaps over the years. Each time I swap out a engine or transmission I fight the driver side bell housing bolts, even when I remove the trans cross memeber and lower the rear of the engine.
Originally had a olds 307 and I swapped in a 283 and th350. I moved the stock motor mounts forward (if I remember correctly, it’s been 15 years or so) and bolted them down. I can’t remember if the 307 was offset to the driver side or not. I’m guessing no because the column shifter linkage was in a bind at the trans and had to tweak it to work. Now the car has a Vortec 5.7 and I’m doing a Muncie swap. It seems like I need to cut or beat the hell out of the driver side trans tunnel for the linkage to fit. Does anyone know if there is offset to the driver side from the factory and if so how much?
