engine package.
Quadrajet is WAY easier to make work right than a Holley. I would never have another Holley. Worthless crap that needs to be beaten to death. Horrible idle and part throttle circuits. You just don't know what you are doing with a Quadrajet and that is why you dislike them. I am willing to take a few months to get it right if that is what it takes. I like carbs I never have to touch after I get them set up and there is no Holley I can get 50k miles out of without any changes. I can and have done that with a Quadrajet in the past. I try to keep my cars low maintenance and do not want to constantly have to mess with them to keep them running. I also hate any and all chrome under the hood of anything I drive. Too much work to make it look right so my engine is a sea of black and is very hard to distinguish from stock so I never have to detail it.
yeah,EFI systems are a little out of my price range right now, and i like more old school technology so the carbs right up my alley lol i was actually looking into an edelbrock 750? ive heard lots of good about edelbrocks aftermarket stuff.
coolchrisp said:
Quadrajets are trash my man. Good for stock to mild build. Other then that you cant get it right, and if you do it wont stay that way long. i would go with a holley/demon for your app. it will be MUCH more user friendly for you out of the box, with minor adjustments.
For all out racing Holleys/Demons are what to use, dont trash talk Q-jets if you dont know how to tune them!!i know of several guys running 11s-12s with Q-jets...The only good Holley that i know of is a double pumper nothing else!! Every car ive owned has been reliable, low emissions, and great mileage thanks to a properly tuned 750cfm Q-jet...
my 403 Olds pushed my cutlass into the low 13s while banging out 18mpg in the city and passing NE Super stringent emissions inspections... DO NOT KNOCK THE Q-JET!
85 Cut your initial post for 83Cut was outstanding. I can't verify it as I don't have the experience with these components but that kind of info is what makes these boards invaluable and our hobby better.
I have a FI GN & love FI especially for a tubo application. That said knowing what can be done with a well done Q-jet I can't see the expense of converting to an EFI on a naturally aspirated application as worthwhile. I applaud those that have done it just not worth it to me.
If I had a drag car big or small block I'd run a holley. If I had a strung out small block street strip car I'd run a holley. Anything short of that and both carbs being equally well set up the Q-jet hands down. The holley is easier to understand and tune but you are going to have to do it alot more often. The Q-jet will idle nicer, stay on tune MUCH longer, stay on tune through abrupt weather changes much better, provide better mileage, have almost FI like part throttle response and operation.
I sent my 800cfm electric choke Q-jet that I got off my junkyard Cadillac motor to The Carb Shop in Ontario CA for a stage II rebuild. (like JET provides only cheaper with better quality control & ACCOUNTABILITY if there is a problem) I gave them my motor & car specs. It came back just a tad rich (which is safe) has performed flawlessly for 9,000 miles ran a 3840 car through the 1/4 at 110 without missing a beat. Starts idles part throttle driveability mileage WOT no adjustments no repairs winter or summer. That would have never happened with a holley.
you guys do know that i started a holley vs q-jet thread for this?
You have almost the exact same buildup I have, cam and heads...with Speed Pro forged pistons, Manley stainless valves and cam-matched springs...full MSD ignition (pro-billet distributor, 6AL, 8.5mm wires, etc). I am, however, using a Weiand Action Plus and a 795-cfm Q-jet.
The only thing I can say is that it's not 400hp, probably closer to 350-375. The cam really doesn't come on until 2200rpms or so, which is kind of a b*tch when it's in front of a 4-speed and just cruising around town. I'd DEFNITELY run a mild converter to make up for this, and a bit extra gear out back. I have a 2.20 1st gear ratio and 3.08s out back, and it's a PIG off the line, but charges hard around 3000rpms. The cam falls off pretty noticeably around 6200. I would also upgrade the rockers; the stamped steel self-aligning rockers kinda suck, but they do work. The Q-jet works great for this application; KILLER response and good mileage if I keep from opening the secondaries: 21mpg with the 3.08s at 65mph!
Car Craft did a very similar buildup, and they got 377hp and 412 lb-ft torque from the buildup, but with an RPM Air gap intake. But FYI: if you use an Air Gap intake (I had one before I got the Weiand), you'll have to cut a hole in your hood for air cleaner/carb clearance; they are TALL. Here's the link to the Car Craft motor:
http://www.carcraft.com/projectbuild/11 ... index.html
Good luck! Any questions, I'll be more than glad to help!!
Oh yeah...and in case you were wondering what th idle was like, well, with open headers and 800rpm, , it sounds JUST like the drum intro to "Hot For Teacher" by Van Halen! 😀 😀 😀
haha i like that comparison.
The reason i said what i did about tha Q-jet was becasue i thought he was building a performance car for racing. If you want good gas mileage i guess a q jet is the way to go. But me, i am ALWAYS under the hood of my cars tinkering with diffrent set ups and tuning. Thats how i get my power, and holleys have never let me down.
The possible reason for the richness is the choice of a 500 Caddy core. From what I have read, the idle feed restriction is set specifically for the engine size from the factory and using one off a 500 on a 350 would therefore make it rich. This is the same problem you would have on a Holley 750 vacuum on a 350 and why people restrict the passage with a small piece of wire to lean it out on that carb. It was originally spec'ed for a 396/375 hp engine so the loss of 46 ci makes it too rich. It is therefore critical to get a carb that originally on an engine of similar displacement to the one you plan to put it on. There is a way to change it, but I do not know the correct procedure and can't give a recommendation. I got mine off a 350 powered 1979 Chevy Van. It took me 5 months to find a core I deemed acceptable ( good shaft bores, engine size, throttle bellcrank), but it runs great with the original primary calibration. I am still working on the secondaries as the rods I am using are too rich, but I have to wait until I have a floor under the driver's seat to work on it again....
