Engine running extremely rich
I finally got the carb rebuilt. It runs, but not that good. It won't run with the choke open at all even after warmed up for 5 or 10 minutes. I can't even crack the choke plate open with out it dying. The idle is extremely high also. It sounds like there is a massive vacuum leak, but I can't find it. I even tried spraying some water around the carb and intake and can't find anything. Tried blocking off all vacuum ports that are being used and nothing changes. It seems to rev up really good with no back firing or anything. I don't know if this is normal, but the secondary air doors don't open at all when I open the throttle all the way for a second. I don't know if they are supposed to only open under load or not. There is no chance of it running while in gear.
Is there a chance of a huge vacuum leak inside the carb?
