It appears the cruise and a/c run through the ECM via the speed buffer and fast ideal relay respectively. Perhaps these are basically just "power-only" circuits (fast idle relay appears to shut off a/c at WOT).The ECM is on its own separate harness. It has nothing to do with the Cruise or AC function. Lockup can be achieved with a simple toggle switch or via an aftermarket kit ( which usually involves dropping the pan )
