Engine update
patmckinneyracing
2,021
36
34
San Antonio, TX
Well I finally started disassembling the entire engine. Began marking wires and taking over hundred pics of the engine bay alone to make sure all goes back the way the factory put it. In the process of removing the wire harnesses throughout the roadrunner. So far not too many problems.
Also pulled up the factory carpet to find floorboards so clean that you could eat off them. There is absolutely no rust and its a miracle for a B body mopar cause normally these cars are plagued with cancer, but luckily this car was garage kept for its entire life with the 2 previous owners. The little bit of rust you see is nothing but a light bit of surface rust.
:thumbs up:
is this the one that has been in your sig?
