To those that have done this install. I can't find an answer to whether you need to use the fuel pump harness in the new kit or if my current fuel pump wiring is fine. My Regal is already setup with an EFI tank and pump since it is originally a turbo T-type. I have the fuel system all setup for my carb which just sets up 7lbs to carb and returns excess to tank. So fuel wise I just need to swap the regulator to an EFI fuel regulator and the fuel system is done. Just would prefer not to cut into my chassis harness to cut and re-run the wires to the new fuel harness if not needed.
