What are you guys doing for fuel systems on your efi LS conversions?
This is the one i am using. It went right into the stock location, hooked up the fuel gauge wire, grounded it and supplied it 12v from the relay block I installed.
It looks like the Buick GN sending unit. The Buicks have a 3 wire connector. What's the 4th wire on the holley for?
gray is 12v from the fuel pump relay, purple is for the fuel gauge, solid black runs to the negative side of the battery and then the black with white stripe grounds to the body back by the tank.
HOPE IM NOT BRINGING UP THE PAST ... BUT ARE YOU RUNNING A STOCK TANK OR THE GN TANK OR DID YOU DO AND BAFFLING LIKE FOAM BLOCKS?
Walbro pump and Corvette regulator to stock tank and sender. Return is plumbed to what used to be the charcoal canister port. That port has a tiny orifice but it can be drilled out once sender is removed from tank.
